HELP! Plot values not matching TimeStep
Old   July 29, 2020, 23:12
Default HELP! Plot values not matching TimeStep
Ali
aligs2920 is on a distinguished road
I am studying turbulent flow around heated cylinders aligned one after another. I am able to simulate the flow and get reports. I made Nusselt number (Nu) reports for each cylinder and created monitors and plots from them. Once the simulation is done, I export the plots to MATLAB for the analysis I want to do.
My issue is that the plots dont show the value of Nu at each timestep. My timestep is 0.005s but the values in the exported files go up in steps of 0.03
I don't know how to fix this since I need to use the proper timestep in my MATLAB analysis.
Is it possible to fix this? Or is there some truncation that Star automatically does when plotting values from reports?
Thanks!
aligs2920 is offline   Reply With Quote
Old   July 31, 2020, 02:25
Ping
ping is on a distinguished road
i imagine you are exporting monitored values from your reports and thus the problem is probably the trigger setting in the monitor not being set to your required setting of time-step
ping is offline   Reply With Quote
starccm+, timestep
How to plot rms values? Jem01 OpenFOAM Post-Processing 3 April 12, 2017 09:52
Velocity values are normal but pressure values are too big rv82 OpenFOAM Running, Solving & CFD 4 April 13, 2015 03:59
[snappyHexMesh] jagged, ragged edges... ziemowitzima OpenFOAM Meshing & Mesh Conversion 138 July 23, 2012 23:41
Need Help- Values not matching umm.. FLUENT 0 February 22, 2008 09:28
hw to plot the values at each grid point rashmi FLUENT 0 April 13, 2006 07:38
