Help Modelling Motion of Propeller Attached to Body (+ Boolean) |
September 11, 2020, 20:43 |
Rep Power: 5 |
I'm wanting some help please with modelling a propeller using a rotation reference frame. I currently have three parts (Part 1 = Fuselage Body with Propeller/Spinner, Part 2 = Wind Tunnel (Rectangular Prism), Part 3 = Cylinder around propeller [to be used for moving reference frame]). How do I use the Boolean Subtract feature to correctly set up the model in terms of input and target parts? I currently have the wind tunnel domain set up as Part 1 and Part 2 being the Input, and Part 2 as Target. Now when I want to model motion, I'm unsure of how to set up Part 3 Correctly. Is it fine that the Propeller and Spinner are attached to the fuselage body as one part (Party 1), or must they be split up separately as another... e.g. part 4? Thank you so much. Last edited by 3liminate; September 11, 2020 at 20:50. Reason: Clarification |
September 12, 2020, 01:19 |
Chaotic Water
Rep Power: 17 |
I'm pretty sure - following tutorials from the User Guide would help you a lot:
page 10021 - Moving Reference Frames: Rotating Fan page 10054 - Rigid Body Motion: Rotating Fan page 10117 - Moving Reference Frames: Marine Propeller in Open Water |
September 12, 2020, 02:18 |
Rep Power: 5 |
Thanks for the reply cwl,
Yes, I've gone through the tutes and understand the process. What I'm stuck with is how I should make the domains. For example, in the Open water propeller, they have the rotating region as the propeller, spinner and cylindrical reference frame. But there's no mention of whether they used a boolean subtract to position it in the domain or how to set up the initial parts. That's what I don't understand. |
boolean subtract, input, motion, parts, reference frame motion |
dynamicFvMesh - tabulated motion of a solid body + mesh morphing | HendrikW | OpenFOAM Pre-Processing | 3 | December 3, 2019 02:05 |
Fluid Domain moving with Rigid body | Lloyd Sullivan | CFX | 3 | August 17, 2018 09:58 |
trying to write a UDF for rigid body motion | niteshrajput | Fluent UDF and Scheme Programming | 4 | December 17, 2014 00:29 |
Rigid body motion on transient fluent mrf | ghost82 | EnSight | 4 | September 6, 2014 11:24 |
Rigid body motion error when restarting a terminated FSI simulation | lingdeer | ANSYS | 1 | May 19, 2013 01:40 |
