Incomplete writing to .csv files during parameter sweeps |
September 4, 2020, 22:08 |
Rep Power: 5 |
Hey everyone!
So I'm running some parameter sweeps on STAR-CCM+ and exporting velocity data to a .csv for each parameter set. I'm noticing that for some sets of parameters the .csv files are incomplete, i.e. don't record the velocity for the full range of points in the mesh. If I run a single simulation with only those parameters, though, this doesn't happen. It almost seems as though, while doing the parameter sweep, STAR-CCM+ doesn't have enough time to finish writing the files? In case it helps, I'm running on AWS, not a local machine. I've tried adding more cores but that doesn't help. I've thought maybe assigning too many cores to STAR-CCM+ causes the parameter sweep to run too fast, hence not giving enough time to finish writing some files. Any and all help appreciated, cheers! |
September 6, 2020, 04:03 |
Ping
Rep Power: 20 |
are you using design manager to do the sweeps and reporting?
maybe run on less cores and even in serial and see if it happens - easy to do in design manager. it could be that the results from some cores are not being sent back quickly enough to the master node for post-processing. if you save all the .sim files from the design manager runs then you can run a macro locally that loops thru and opens each and does the csv file write. |
September 17, 2020, 04:40 |
Rep Power: 5 |
Yeah running a macro locally would be one way. I'll try running with less cores. Thanks mate!
parameter sweeps, star-ccm+ |
Display Modes | |
Setting up Boundary Conditions in CFX using .csv files. | knikkhilraj | CFX | 2 | May 7, 2018 09:12 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
Writing geometry files in STAR-CD | Sachin | Siemens | 5 | April 22, 2008 17:38 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
Pb with writing the Case and Dat files | Sam | FLUENT | 2 | May 14, 2004 12:16 |
