September 8, 2020, 18:27 |
AMG Warning
Yunus Aysan
Rep Power: 5 |
Dear Esteemed Members,
Thank you for taking the time to read my post! Can anyone shed some light on what may be causing the warning message in the attached image? AMG Warning Message.jpg It started at around the 1000th iteration, and continued until I stopped the simulation at the 5000th iteration. As far as I am aware I am already using double precision which is the 64-bit version of STAR, or so I have read online. I've attached a screen shot of the task manager which shows I am running the 64-bit version. Is there a possibility that STAR is in fact running in mixed-precision mode even though the task manager shows 64-bit? 64bit.JPG Could this be related to bad cell quality in the mesh? Can I ignore this warning as the results I have attained appear to be reasonable? Any advice and/or guidance is much appreciated, thank you! |
September 9, 2020, 08:06 |
Matt
Almost certainly the result of poor quality mesh. Are you using automatic surface repair in your mesh setup? If not, use it. If so, you may need to resort to manual surface repair or try the cell quality remediation option.
September 9, 2020, 17:55 |
Chaotic Water
If i remember things right - might in particular be an issue with Interface between Regions.
September 22, 2020, 09:53 |
#4 | |
Yunus Aysan
Rep Power: 5 |
Hi, thanks for your replies.
I switched to laminar flow and models, and the warning message went away - or the simulation did not complete enough iterations for it to show up (The solution appeared to have converged). Quote:
I would obviously like to keep the models as turbulent so I will try to play with the mesh manually. |
amg, precision, solver |
Caffa 3D code | Waliur Rahman | Main CFD Forum | 0 | May 29, 2018 00:53 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
