STAR-CCM+ can only run with half of the machine's cores |
September 17, 2020, 22:20 |
Rep Power: 5 |
Hey everyone,
My colleagues and I have noticed that we're only able to run STAR-CCM+ in parallel with a maximum of half the number of cores there are on whatever machine we're using. So, for example, a machine with eight cores could only run STAR-CCM+ in parallel with four cores. Is there some way to change this? Cheers |
September 18, 2020, 05:38 |
Ana
Rep Power: 5 |
I have the same question! any help??
September 18, 2020, 18:05 |
Chaotic Water
Rep Power: 17 |
Are you referring to launching Star-CCM+ itself - or to the performance?
September 20, 2020, 08:55 |
#4 | |
Sebastian Engel
Rep Power: 20 |
Are you sure that you have 8 physical cores? Or do you have 8 virtual cores and only 4 physical cores. You might need to check the specs for your cpu. |
September 20, 2020, 21:05 |
Rep Power: 5 |
STAR-CCM+ launches and runs but tells me that I've assigned to many cores and defaults to running with some set number of cores (not sure what this is, maybe one). For example if I'm running a virtual machine with 16 cores and I try to run STAR-CCM+ with 10 cores, it will tell me that I've assigned 2 too many cores.
September 20, 2020, 21:07 |
Rep Power: 5 |
I'm running on AWS so can vary the number of virtual cores. I have 4 physical cores on my computer, though I don't see how this should matter. No matter how many cores I assign to my virtual instance, STAR-CCM+ still won't run with any more than half that number of cores. Weird.
September 22, 2020, 09:00 |
#7 | |
Sebastian Engel
Rep Power: 20 |
September 23, 2020, 23:32 |
Rep Power: 5 |
The important part of the error is this:
Starting STAR-CCM+ parallel server ************************************************** ********************************** Warning: The host machine [...] has been over-subscribed. The host has 8 too many processes allocated to it. Over-subscribing a host can severely affect performance. ************************************************** ********************************** This is from trying to run STAR-CCM+ with 16 cores on a virtual machine with 16 cores. |
October 4, 2020, 09:13 |
#9 |
Sebastian Guaqueta
Rep Power: 6 |
Star CCM+ comercial licence mode is per cores, maybe licence you are using is only able to use 4 cores and you need to pay for more capacity, check licence setting.
October 6, 2020, 05:11 |
#10 | |
Sebastian Engel
Rep Power: 20 |
However, this is just a warning in my case. StarCCM will open anyway with the given number of workers. I believe this is just a reminder for users, that you should only use the actual number of pyhsical cores per host. Using additional Hyperthreading (virtual) cores and alikes will not increase the performance. In most cases it will actually increase the run time. So if you are sure, that you have more physical cores than StarCCM recoqnizes, then just go on. In any case, i suggest to run a brief benchmark on your virtualized system to make sure. Run a simulation with 4,8,16 cores (or something like that) and see for yourself which number of workers result in the fastest simulation for that respective system. I believe, there is also a command-line option for benchmarking the number or cores - have a look in the manual. Best, Sebastian |
October 10, 2020, 05:57 |
#11 | |
Rep Power: 5 |
On your point about using additional cores, are you saying that while it's possible that a simulation may run faster on a system with 16 physical cores than on a system with 8 physical cores, running the simulation with 8 physical cores and 8 virtual cores might actually be slower than just running with 8 physical cores? Cheers |
October 10, 2020, 15:31 |
#12 | |
Sebastian Engel
Rep Power: 20 |
Yes, i am pretty sure that is true for the majority of use cases in cfd. But again, to be certain an easy benchmark can be used. |
October 12, 2020, 20:30 |
#13 |
Hi
I thought I'd clarify a few points: 1/ You cannot access physical and virtual cores at the same time. Virtual cores is basicaly giving access to only a % of a physical core because of a VM or hyperthreading. Through a VM, you will only ever have access to a virtual core, that's the whole idea of a VM. 2/Most cloud provider runs a VM with hyperthreading ON. That means that you get < 45% of the performance of a physical core per virtual core. 3/You might find that you get better performance running on 16 virtual cores, depending on your model. 4/STAR-CCM+ detects physical cores in its warning message. 5/trampoCFD.com runs on physical cores, we don't run through a VM. If you'd like to run your simulations fast, we can give you access to more than 150,000 cores that scale down to 10,000 cells per core. That's sufficient for most users :-) Please email me gui@trampocfd.com if you'd like to learn more. Best regards, gui@trampoCFD |
how to open star ccm 6.04 version file in older versions | pritam.edke | Siemens | 2 | June 25, 2012 03:14 |
Fluent Vs Star CCM | firda | Main CFD Forum | 3 | February 26, 2011 02:51 |
star cd cannot run | josh | Siemens | 6 | October 16, 2006 14:14 |
Can fc5 run Star? | lizhihua | Siemens | 8 | May 24, 2006 09:41 |
How to run star design on unix | AB | Siemens | 1 | October 1, 2004 13:29 |
