Resistance Error
Hi
I working on simulation semi displacement. for present simulation i do mesh steady in froude number 0.35 and my results good. but in Fr = 0.2 The resistance results are high error. Summary of simulation settings: Number of prism layer mesh = 10 time step = 0.001 y+ in Fr = 0.35 = 50 Do you have a suggestion? |
pressure resistance is just as important as skin friction so the mesh of the free surface, kelvin wake and rear wake are very important.
you might have a good boundary layer modelled but also ensure the mesh from the last prism layer to the volume mesh is is not growing too fast. other ideas: how good is your geometry compared to that used in testing? run for long enough based on monitored reports? how reliable is the measured data - these are difficult measurements to make and it is common to find poor data? |
2. Does the prism layer thickness the resistance results? |
yes the 1st prism layer is very important and you need to follow the normal guidelines for its thickness dependent the wall physics you choose. if using a high y+ wall treatment then the cells after the 1st simply need to grow gradually eg < 50% bigger each step out to the core mesh and sometimes you only might need 2 prism layers to achieve this.
cd-adapco before siemens had some wonderful guidelines and papers about this done by prof peric and you should be able to find this or ask a support engineer. i remember one that gave guidelines for doing both model scale and full scale ship hulls. but one important point i remember was that to achieve accurate results you did not need to use low y+ models and the crazy mesh numbers that it requires to fully integrate the flow across the boundary layer. |
