Resistance error with deceleration
Hi
I work in the field of high speed craft simulation in Star CCM+ software. I did the mesh validation and time step at speed 4.5 m/s (Fr = 1.45) and the results were good.Then I did the simulation for speed 3 m/s (Fr = 0.94) and the results were good.But the results for the speed of 1.5 had a large error (25%) in the amount of resistance.(There is also no numerical ventilation) 1. Do you have a suggestion? 2.What should change in the simulation settings as the speed value changes? |
Due to the complexity of the body shape, trimmer mesh can not be used. Tested in a vessel laboratory in two degrees of freedom (heave & pitch) I want to compare my results with laboratory results.So I can not open all the degrees of freedom |
