March 4, 2021, 11:44 |
Spilt surface by patch
Rep Power: 5 |
Hi all
I am trying to write a Macro, that imports an .stl file and use the "Split by patch" command and rename some of the patches to "New_Shaft". This will be done in a loop for a bunch of simulations. The problem I run in to is that the IDs/numbers of the "Part surface Patches" changes every time I import a new STL file. The position in the list of ID are the same every time, so is there any way I can choose it from the position or get the list with the IDs instead of referring to the IDs directly (or maybe do it another way)? The comand I use is as follow, where "13898, 13899, 13904" is number 4, 5 and 10 in the list of IDs: Code:
cadPart_0.splitPartSurfaceByPatch(partSurface_0, new IntVector(new int[] {13898, 13899, 13904}), "New_Shaft"); Fig1.png Fig2.png |
April 26, 2021, 04:00 |
Same question, any help?
Sam
I encounter the exact same problem during trying to ease my work load by Marco, have you figure it out, SandLand?
April 27, 2021, 04:06 |
A workaround
Sam
An update for Sandland and all the people may encounter the same problem:
I found that the using split by angle function can fix my question, the name ('Block Surface 1', 'Block Surface 2', ...) seems repeating at the same surface every time I call the function (at least so far). Attached the my recorded Marco FYR, but record for your own simulation is highly recommended: private void SplitSurfaces() { Simulation simulation_0 = getActiveSimulation(); SimpleBlockPart simpleBlockPart_0 = ((SimpleBlockPart) simulation_0.get(SimulationPartManager.class).getP art("Domain")); PartSurface partSurface_0 = ((PartSurface) simpleBlockPart_0.getPartSurfaceManager().getPartS urface("Block Surface")); simpleBlockPart_0.getPartSurfaceManager().splitPar tSurfacesByAngle(new NeoObjectVector(new Object[] {partSurface_0}), 89.0); partSurface_0.setPresentationName("Outlet"); PartSurface partSurface_1 = ((PartSurface) simpleBlockPart_0.getPartSurfaceManager().getPartS urface("Block Surface 2")); partSurface_1.setPresentationName("Sides -Y"); PartSurface partSurface_2 = ((PartSurface) simpleBlockPart_0.getPartSurfaceManager().getPartS urface("Block Surface 3")); partSurface_2.setPresentationName("Bottom"); PartSurface partSurface_3 = ((PartSurface) simpleBlockPart_0.getPartSurfaceManager().getPartS urface("Block Surface 4")); partSurface_3.setPresentationName("Top"); PartSurface partSurface_4 = ((PartSurface) simpleBlockPart_0.getPartSurfaceManager().getPartS urface("Block Surface 5")); partSurface_4.setPresentationName("Sides +Y"); PartSurface partSurface_5 = ((PartSurface) simpleBlockPart_0.getPartSurfaceManager().getPartS urface("Block Surface 6")); partSurface_5.setPresentationName("Inlet"); } |
macro java, split a surface, stl file |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 457 | March 27, 2024 00:59 |
steadyUniversalMRFFoam Tutorial fails in MixingPlane | HenrikJohansson | OpenFOAM Bugs | 0 | February 14, 2019 04:48 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
