Automating work flow for a large number of flow cases - star ccm+ |
March 22, 2021, 07:14 |
Nathan
Rep Power: 6 |
I have a set of 1000+ 2D geometries on which I would like to conduct SA flow evaluations. For each case, I'm only varying the target geometry and flow velocity. What options do I have to automate the preprocessing, execution, and post-processing of each run?
To be more specific, I'm trying to replicate this study within Star ccm+: https://github.com/thunil/Deep-Flow-...ata/dataGen.py As you can see all the pre-processing, execution, and post-processing steps are handles within this fairly straightforward python script. I know equivalent macros can be created with java for starccm+ but I have no experience with it. Are there any python based methods for starccm+? I also know add-on packages such as are used for design exploration. Would that be a possible solution? Finally, ABAQUS had a great feature that recorded all your actions when creating a flow case. You could then see the code for the case and change as necessary to run the same test over a large number of boundary conditions. Does star ccm have similar functionality? |
automation, java, macros, python, star ccm |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
