Changing the "Contour Style" does not changing the view
Like Tree1Likes
  • 1 Post By Peresvet
Old   April 4, 2021, 14:23
Default Changing the "Contour Style" does not changing the view
Yağız Ataberk ERİŞTİ
yagiz is on a distinguished road
Hi everyone,
I did an analysis, it converged properly and I got my results. But I also want to use the analysis's photo in my report. It doesn't look nice since there is no difference changing the contour style from automatic to smooth filled or just "filled" etc.. When I changed it to Smooth Filled+Lines, it shows the lines but its still not "smoothing" the view. Because I am doing a research, my mesh is very fine and enough I suppose.
Any ideas?
Cheers.
TOBB ETU - Mechanical Engineering
yagiz is offline   Reply With Quote
Old   April 4, 2021, 14:37
I figured it out,
I clicked the colour bar and changed levels from 32 to 320.
Old   April 4, 2021, 20:02
Peresvet
Peresvet is on a distinguished road
Originally Posted by yagiz View Post
I figured it out,
For high-quality shots, 128 is enough, plus anti-aliasing.
However, this is only for the quality of the fill. Then a fine mesh and a multistep solver method are needed for a high-quality water surface. This is necessary to keep the GFL less than 0.15 and to make the solution faster. If this is not done, then you will have to take a long time and it is not a fact that the edges of the cells will not stand out in contrast.
yagiz likes this.
Peresvet is offline   Reply With Quote
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so immortality OpenFOAM Pre-Processing 15 April 7, 2024 12:35
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 07:18
