Fluid Film on parts of cylinder
Old   October 20, 2021, 02:36
Default Fluid Film on parts of cylinder
tcr2231 is on a distinguished road
Hi!
I am working on a simulation of the thermal effects of a fluid film on parts of a solid cylinder. For this problem, I used two different approaches, both showing a problem that I cannot solve.
1.) Geometry: Horizontal cylinder (solid), wrapped in a cube (gas). The cube has a shell region on the boundary to the cylinder in which the fluid film is supposed to flow. For the fluid film, I used a mass source term (field function) that is positive at the top of the cylinder and negative at the bottom, so there is a mass source at the top and a mass sink at the bottom. This works so far, but my problem is that I did not find any setting to set the temperature of the film "coming out" of the mass source. Does the mass source use the initial film temperature, or how am I able to set it?
EDIT: Solved -> Not possible, you have to determine a heat source corresponding to the mass source term to close the equations
2.) As an alternative, I let the box intersect with the cylinder and performed a subtract-action to generate edges of the box at the intersections with the cylinder (see picture attached). I would like to set the edges at the top (positive y-direction) as mass flow inlet for the film, the edges at the bottom as outlets. Unfortunately, StarCCM+ does not let me split the edges but does generate one boundary for all of the intersection edges. Does anyone of you have an idea, how to set separate boundary conditions for separate parts of the intersection edge?
EDIT: Solved -> When splitting the faces of the box, the boundary edges are split automatically as well. Works even better with CAD parts instead of simple geometry parts
Thank you so much in advance!
tcr2231 is offline   Reply With Quote
Old   October 22, 2021, 13:39
[post deleted, see edit above]
Depositing fluid on rotating cylinder kgschuch FLUENT 1 October 6, 2020 13:31
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 16, 2020 23:44
Fluid Film Model Energy Equation khal STAR-CCM+ 0 June 18, 2020 07:25
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Fluid in a rotating cylinder Fluid Novice Main CFD Forum 1 December 17, 1998 17:25
