November 23, 2021, 14:01 |
Part is not inherited after subtract
cplatano
Rep Power: 4 |
Hi everyone!
I am trying to subtract a rear wing from a wind tunnel. In the Subtract Operation I have selected the rear wing as well as the other components that I want to subtract from the tunnel. However I am not able to find that specific part under Regions when I try to assign it to an already existing Boundary. When I execute the Subtract Operation no warnings appear in the Output. Nevertheless, when I check the Parts under geometry, the rear wing is missing from the Inherited Parts (I suspect that's why I can't see it while selecting the boundaries). Does anyone of you know why this might be happening? A solution would be helpful. |
November 23, 2021, 16:09 |
Lucky
Rep Power: 65 |
You need to select Keep Tool Bodies if you want to keep the body that is being subtracted.
boundaries, inherited parts |
Display Modes | |
[snappyHexMesh] snappyHexMesh can't create a fine Mesh from stl from Rhinoceros | Taghi | OpenFOAM Meshing & Mesh Conversion | 13 | May 4, 2017 16:48 |
Stress Equation and Implicit part | Tobi | OpenFOAM | 1 | July 13, 2016 07:25 |
replacing of shock tube high pressure part with a boundary condition for low pressure | immortality | Main CFD Forum | 0 | May 2, 2013 14:30 |
what boundary condition is proper for simulation of shock-tube low pressure part? | immortality | OpenFOAM Running, Solving & CFD | 0 | May 2, 2013 14:22 |
Algorithme choosing for solid part analysis of conjugate heat transfer | Anna Tian | Main CFD Forum | 4 | January 20, 2013 17:11 |
