Volume flow rate as the boundary condition
Old   May 21, 2022, 04:27
Default Volume flow rate as the boundary condition
Zhang Yan
Erikaaa is on a distinguished road
Hello everyone!
I faced some problems when using Star-CCM+.
(1) In engineering field, volume flow rate is more commonly used than mass flow rate. Therefore, I would like to ask how to set up volume flow rate inlet in Star-CCM+. If there is no direct way to set volume flow rate, is there an alternative method?
(2) The outlet is usually set as pressure-outlet. I want to ask if continuity can be guaranteed (I mean the inlet and outlet flow rates are equal).
I would appreciate it if someone could help me.
Thank you!
Erikaaa is offline   Reply With Quote
Old   May 23, 2022, 01:50
Lucky
Volumetric flowrates are specified using velocity inlets and very rarely velocity "outlets."
You are solving a momentum balance equation and a mass continuity equation, so your result had better meet continuity criteria or you have another problem.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Mass flow rate boundary condition with negative values hebe2u. CFX 1 December 27, 2016 03:53
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 11:14
