June 28, 2022, 05:27 |
simulating flow over obstacles in a flume
I am simulating the flow over a singular obstacle in flume flow, maintaining all set parameters but moving the distance between the inlet and the obstacle leads to a big decrease in drag coefficient, any ideas why? For a singular square it should be around 2.1, which i get close to at 1 Diameter upstream, however at a reasonable distance of 5 Diameter it is below 1 (should remain similar to the first value). Any help appreciated
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Boundary conditions for flow in nozzle | kgevers | FLUENT | 0 | July 26, 2015 12:46 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Simulating a high pressure flow through a valve | Kromagnsss | FLUENT | 8 | July 2, 2010 05:20 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
