Surface intersect itself error message while doing volume meshing |
June 21, 2022, 09:34 |
Kerala
Rep Power: 3 |
I was trying to volume mesh an assembly. Before that itself using surface repair option , I had made sure that there were no errors in the geometry. Still, when I am trying to do volume meshing ,error message "the surface intersect itself " is showing . The volume mesh is getting failed. What should I do to rectify this?
June 21, 2022, 23:00 |
Chaotic Water
Rep Power: 17 |
Right-click your parts and select Repair Surface - to check where that happens.
June 22, 2022, 03:41 |
Kerala
Rep Power: 3 |
I had already cheched in surface repair. There is zero error showing]
June 22, 2022, 03:51 |
Chaotic Water
Rep Power: 17 |
Did you check the tessalated (like "geometry") surface - or the remeshed (by Automatic Mesher) surface?
June 22, 2022, 12:57 |
Kerala
Rep Power: 3 |
June 22, 2022, 13:10 |
Chaotic Water
Rep Power: 17 |
Check the remeshed surface - it is used during construction of the volume mesh.
star ccm +geometry, star ccm+, star ccm+ error |
Display Modes | |
multiphaseEulerFoam FOAM FATAL IO ERROR | qutadah.r | OpenFOAM Running, Solving & CFD | 11 | December 10, 2021 20:18 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
[ICEM] Meshing the Fluid Volume of a Fibrous Membrane/Media--Help with errors/settings? | ANT | ANSYS Meshing & Geometry | 4 | July 10, 2013 00:20 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Volume 1 has invalid topology for mapped brick meshing | georgewar | ANSYS | 0 | July 24, 2011 16:02 |
