discontinuity in Prisim layers at solid liquid interface |
September 2, 2022, 03:37 |
Bal
Rep Power: 4 |
Hi All,
as you can see in the attached picture there seems to be a discontinuity in the prism layer at the solid/liquid interface? what are proper causes for this?MicrosoftTeams-image (1).png |
September 9, 2022, 13:52 |
Lucky
Rep Power: 65 |
That's the prism layer retraction kicking in. Is there an adjacent surface where prism layers have been disabled or a large deflection in the two boundary normal vectors? Are the prism layer settings the same on all surfaces or are they different and forcing one layer to retract to match another layer?
September 13, 2022, 12:56 |
#3 | |
Rep Power: 14 |
September 14, 2022, 08:18 |
Yes. There is no discontinuity there. Layers compresses near a corner. One way to get rid of this is by increasing surface size. But I would suggest to not bother. There is no problem with this type of mesh.
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[ICEM] Solid mesh with no prism layers | Roberto Meloni | ANSYS Meshing & Geometry | 7 | September 11, 2014 09:38 |
Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 02:18 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
