cant continue again the simulation after stop (crash stop) |
September 3, 2022, 09:59 |
i have a simulation for a seekeeping problem for a vessel in head sea. i create the setup and start the run, seems everything is ok, the run continue around 5 seconds (physical time). i have 2 problem with the setup: 1- when i stop, save and closed the run, and change the number of cores it will not continue again! i dont receive any error! it just not continue. 2- our server have a problem, every 12 hours it will turn off. (because of electricity problem) i activated the autosave for each 200 iteration, when i start the run again to continue, i will see same problem like above. (the run will not continue, even with same number of cores) please advise me what should i do!? thanks in advance |
September 3, 2022, 10:03 |
for your info, the setup is based on overset mesh, with 2 degree of freedom
i use "free motion" setup in DFBI. number of mesh is around 5 million, time step is 0.0025 s |
Why the change of writeInterval will cause simulation crash? | kclement1993 | OpenFOAM Running, Solving & CFD | 1 | March 26, 2020 16:42 |
Add a stop criteria for an unsteady multiphase simulation | Jeneas | OpenFOAM Pre-Processing | 0 | May 18, 2018 09:22 |
can not continue running simulation with trn file | mao | CFX | 5 | September 23, 2016 10:31 |
Simulation crash with dynamicRefineFvMesh and kOmegaSST - OF 2.3.x | nathanael | OpenFOAM Running, Solving & CFD | 4 | June 29, 2014 17:02 |
Expert parameter to stop the fluid flow simulation | KK | CFX | 1 | February 25, 2008 16:29 |
