Visualizations / Scenes Cause Immediate Crash in Ubuntu 22.04 |
Kellis
Rep Power: 8 ![]() |
Hello all,
First off, let me start by saying that I realize Ubuntu is not a supported OS for StarCCM+, and my life would be easier if I were using a supported OS, but I would like to use StarCCM+ on my Ubuntu machine to allow working on multiple projects in other software at the same time. I have downloaded StarCCM+ v2206 from the Siemens Support Center and installed it successfully on my machine (a Dell 5570 laptop with a 12th gen i7 proc running Ubuntu 22.04) with the provided script. I don't believe there are any issues with the installation process itself, as I can successfully start StarCCM+ and carry out all of my normal pre-processing steps. However, trying to load any sort of scene / visualization (e.g. starting a sim and viewing residuals, looking at the mesh, etc.) causes an immediate crash and the program exits with the following error: Code:
LLVM ERROR: Do not know how to split the result of this operator! Code:
libGL error: MESA-LOADER: failed to open iris: /usr/lib/dri/iris_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: iris libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: swrast libGL error: MESA-LOADER: failed to open iris: /usr/lib/dri/iris_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: iris libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri) libGL error: failed to load driver: swrast X Error of failed request: BadValue (integer parameter out of range for operation) Major opcode of failed request: 149 (GLX) Minor opcode of failed request: 3 (X_GLXCreateContext) Value in failed request: 0x0 Serial number of failed request: 31 Current serial number in output stream: 32 Thanks, Kellis |
Kellis
To anyone in the same boat: it seems that including the "-mesa" flag upon startup fixes this issue, e.g.:
/path/to/star/binary/starccm+ -mesa -other -options |
Chaotic Water
Rep Power: 16 ![]() |
But from what I remember from the user guide - mesa is the slowest (software-rendered) graphics.
#4 | |
Rep Power: 5 ![]() |
I'm pretty much in the same boat, but running Rocky Linux which is officially supported and visualizing the server through a remote connection. |
Display Modes | |
[waves2Foam] Compilation on Ubuntu 22.04 | Felix_Sp | OpenFOAM Community Contributions | 0 | September 24, 2022 11:59 |
[OpenFOAM.com] Problem installing OpenFoam 2206 on WSL2 with Ubuntu 22.04 LTS | amolgole73 | OpenFOAM Installation | 3 | September 7, 2022 14:25 |
[OpenFOAM.com] Install OpenFOAM 2.1.x on ubuntu 22.04 | i.linch | OpenFOAM Installation | 6 | September 7, 2022 08:39 |
[OpenFOAM.com] Install OpenFOAM 2112 in Ubuntu 22.04 | tRock | OpenFOAM Installation | 5 | May 28, 2022 04:48 |
Gambit Crash in Ubuntu 14.04 | cfluid | ANSYS | 1 | October 23, 2014 09:16 |
