Advancing Layer Mesh Confusion
Like Tree5Likes
  • 2 Post By cramr5
  • 1 Post By cramr5
  • 1 Post By Aeronautics El. K.
Old   March 12, 2023, 17:41
Default Advancing Layer Mesh Confusion
Sabri
racerter is on a distinguished road
Hi fellow fluid dynamics peeps,
I was making mesh of a 3d wing using the advancing layer method.
However when looking at certain sections of my mesh I noticed an irregular behaviour of the near wall layers as shown in the attached photos.
What could have caused this issue and is there a way to fix this?
racerter is offline   Reply With Quote
Old   March 13, 2023, 05:39
Marc Ricart
cramr5 is on a distinguished road
Are you sure that's real or just a consequence of the location of the cutting plane?
Also, hoooly molly, how many layers do you have?
cramr5 is offline   Reply With Quote
Old   March 13, 2023, 05:50
Sabri
I am not sure, but when I look at different cutting planes I do not have this visual and irregularities.
hahah I got 40 layers. I wanted a prism layer total thickness of 0.05m so that I can have a very accurate boundary layer? I guess youre hinting it might be excessive? >.<
Old   March 13, 2023, 06:11
Marc Ricart
mm ok, I would try to run a mesh quality check to see if it returns some errors and even try running it and check the results if they make sense
haha I don't know, I think it depends on what you do, if it's academic I think it might be OK, maybe too much (If my memory is not bad I would say 20-25 is fine). My CFD is mostly professional and there you need a compromise between simulation time (and size) and accuracy and you usually use less elements to speed up simulations and get "good enough" results.
End of the day, if you have a machine powerfull enough to run it ok go for it. You could potentially have problems if your mesh is too small but hard to say beforehand if that will happen. Just try and check
Old   March 14, 2023, 04:01
Sabri
Sorry for late reply, I am very new to the forums and I hadn't even noticed I got a response
When you mean mesh quality check do you just mean to run it and check the simulations? I am new to star CCM software so I am not sure what features I have avaible.
Your advice was very helpfull regarding number of layers! I decreased it and it gave me much more cells to play with around my mesh! I had initially thought it was vital to massively discretize the near layer prism cells (to capture the boundary layer) so if anything I was initially worried 40 wasn't even enough hahah >.<
My work is also for professional applications so definitely speed was an issue I had, I only have like 3e6 cells to play with
Old   March 14, 2023, 04:24
Marc Ricart
When you mean mesh quality check do you just mean to run it and check the simulations? I am new to star CCM software so I am not sure what features I have availabe.
No worries, no need to apologize. Yes, I would do:
- Run the mesh diagnostics in "MESH-DIAGNOSTICS" and see if you spot any problematic region.
- Run the simulation and take a look at the residuals and see if everything converges as expected, if values like tke or tdr stay high then open a scalar and locate the problematic areas and improve mesh on that area.
Your advice was very helpful regarding number of layers! I decreased it and it gave me much more cells to play with around my mesh! I had initially thought it was vital to massively discretize the near layer prism cells (to capture the boundary layer) so if anything I was initially worried 40 wasn't even enough hahah >.<
Oh ok, if it's professional then go low. Keep in mind that even F1 teams use something like 4-10 layers depending on the area in order to speed up simulations and get "good enough" results. You know your application and how accurate the near wall simulation have to be. You can also monitor the Wall y+ value and play with the layers to keep it under control.
I would also recommend use of "Custom surface mesh control" and reduce the number of layers in areas of little or no interest. That will allow you to reduce overall mesh count
Old   March 14, 2023, 04:56
Sabri
Thanks alot for the headsup, I was not aware of the mesh diagnostics tool . Until now, I was only looking at the residuals and comparing with wind tunnel data, this definitely sped up my process alot.
I am suprised about the 10 layers. Because I was always in the impression the near wall thickness should be circa the size of a boundary layer (2-3cm for laminar). But with 10 layers, how will I be able to sufficiently measure boundary layer effects? Or am I completely misinterpreting what the near wall cells are meant to do?
Old   March 14, 2023, 05:18
Marc Ricart
10 or even less, most of the car was 3 or 4 I think. Well, keep in mind that the models are already 250-350M cells for a HALF F1 car and can take something around 8-10h from mesh to solution.
I am no CFD dev expert, I was more of an end user but from what I know the results where good enough. I think in some areas they used some surface roughness settings to adjust CFD to reality for example.
Sure you want to push to the limit but you also want a stable aero car at multiple yaws and car attitudes so you cannot design to the limit either. Additionally, parts are Wind Tunnel tested and validated before they hit the track and even with that some problems may happen.
Old   March 14, 2023, 05:42
Sabri
I understand. This is very insightfull, however (and please correct me if I am wrong) I would imagine aspects such as boundary layer performance are not important for automotive applications (whereas for aerospace I would imagine they play a bigger role in performance), I doubt there are even much of a boundary layer with the exception of spoiler.
However, I am going to take your advice, I am going to try and see how a lower prism layer count effects run times and accuracy.
I am not sure I understand what you mean with Parts being wind tunnel tested and some problems may happen. Do you mean that Wind-Tunnel verification is inadequet?
Old   March 14, 2023, 08:32
Marc Ricart
Well for open wheel race cars tested at 60% Scale there is so much you know and you can do but differences like tyre shape, tyre deformation, transient effect (see pourpoising), etc are still there and can make misscorrelation happen.
Not saying it's not good but it's not perfect and real world testing is still needed for some things.
Aeronautics El. K. likes this.
Old   March 14, 2023, 14:15
Lefteris
Aeronautics El. K. is on a distinguished road
One does not exclude the other. You can specify the 1st cell height, the total thickness and the number of layers or the stretch factor.
With regards to quantifying the effect of the prism cells on the solution, you could do a systematic study of the y+ and the number of layers.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   March 15, 2023, 03:32
Sabri
Oh I get what you meant now, yeah definitely, I was aware of the issues with wind tunnel testing, but atm my wing is still the design process. Thus I am using the windtunnel data of another reference model to get a rough estimate of the validity and errors I could expect of using Star-CCM for high fidelity design.
Old   March 15, 2023, 03:39
Sabri
Understood, my process was to estimate the boundary layer with some mathematical relations. And then use the tools in cfdonline to measure the near wall thickness, after that I just used my judgement and some test runs to guestimate a sufficient layer number. Sadly, my computer is quiet weak so I am unable to do a design parameter study given my time restraints.
Old   March 15, 2023, 04:57
Lefteris
That's pretty much the approach.
I believe you said you're doing this in an industrial setting. I don't know what kind of industrial setting that is but in my case, I get to review CFD reports from various providers and about 90% they haven't done a mesh sensitivity study. So they have no idea about the error of their simulations.
And because that stuff is for regulatory compliance it matters a lot.
Then people come up with all sorts of excuses why they didn't do it or cannot do. And my answer is pretty much the same all the time... Excuses are not getting the CFD study approved. Simple as that.
So, what I mean to say is, try to do a mesh sensitivity. And you can link the prism layer parameters to the base size of the mesh so your layers are refined along with the surface and the volume mesh.
Now if the CFD you do is for internal consumption it may not matter that much, but if your work is going outside your organisation, someone might be asking you questions later on.
Lefteris
Old   March 16, 2023, 03:56
Sabri
Thanks so much for your response. Even though this is for internal consumption only, I do wish to do a mesh sensitivity study in the future at my work's HPC, my own work laptop struggles with refined meshes hence most analyses I do are constrained within a low cell count.
However before I can send it to the HPC, I wanted to get a mesh with a base size of 1 to be in somewhat an acceptable form such that, my supervisor, wont have to play with mesh parameters much.
I must say I am suprised to hear from you people do not do mesh studies for external work. I cannot imagine what sort of excuses they have for not doing so.
Old   March 16, 2023, 04:10
Lefteris
I get you. It's good to be mindful of the resources.
To make your life easier, perhaps you already do that, you can link the base size to a characteristic dimension and have it as a multiple of that. Makes it easier to make changes later.
As for excuses, they usually say that they don't have resources, that they solve the flow on laptops or workstations.
And the problem is that often the mesh they present, the cell size, doesn't have much consideration for the scale of the phenomena they investigate..
Lefteris
Old   March 16, 2023, 10:47
Sabri
Yup I made sure my mesh is all linked to the base size such that in the design study it wont need much interaction.
Damn, I guess not everyone in the profesionnal field has a grasp on y+ application?
Old   March 16, 2023, 10:56
Lefteris
I'm glad that you're so positive and you think that it's just y+ that's outside of their grasp...
Lefteris
Old   March 17, 2023, 03:35
Sabri
Hahaha oh noo XDD. I cant lie I only began CFD as a professional career a few weeks back, so all my experience is just from my uni courses.
So I wont judge them too hard yet cos Ill definitely be making my stupid mistakes as well.
Old   March 17, 2023, 05:06
Lefteris
We all started from the same starting point I guess. I'm not judging anyone, in fact I still think I'm not very knowledgeable myself, but I know my limitations and I read and I try to get out of my comfort zone.
However, when certification authorities are involved, I would expect CFD studies to be solid. (See what happened with the FAA and the 737MAX, which is not CFD related but some entities dropped the ball...)
I think what is important is to think about the physics of the problem under consideration. Large scale phenomena, small scale phenomena and the associated timescales. Then, in an industrial setting, you decide how much detail is needed and what you can afford (money-wise, and also time-wise... and because time is money, actually money-wise :P) and then you build your model accordingly. Just don't cut corners, there are a few fundamental aspects that need to be there.
cwl likes this.
Lefteris
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 11:50
[snappyHexMesh] No generation of layer onto zerothickness surface crubio.abujas OpenFOAM Meshing & Mesh Conversion 3 October 25, 2022 03:20
[snappyHexMesh] Bad/jagged mesh around intersection of two .stl bodies MBttR OpenFOAM Meshing & Mesh Conversion 7 October 14, 2016 03:57
[snappyHexMesh] Propeller mesh not smooth nortanapura OpenFOAM Meshing & Mesh Conversion 0 May 16, 2014 03:26
