Natural convection is not converging
1 Attachment(s)
Hi all,
for my master thesis i need to simulate a heatingsystem for a church. Therefore i simplified the construction to a big room with one block of heat source in the middle. There is a small heat flux loose through the walls an i already added the model S2S-Radiation (gray thermal radiation). The velocity vectors make sense to me, but the block doesnt heat up the surrounding space. I am using the version STAR-CCM+ 2022.1 Build 17.02.007. The phsyics models are: All y+ wall treatment gas gradients gravity gray thermal radiation ideal gas K-Omega Turbulence Radiation (S2S) RANS Segregated Flow Segregated Fluid temperature Solution interpolation SST (Menter) K-Omega Steady 3D Turbulent View factors calculator Wall distance Any ideas what i could do? Thank you in advance! |
what are the boundary conditions? maybe the flow is because of the boundary conditions?
PS:I was once faced with a similar problem, as the coolant can't bring away the heat of batteries, then I used impress/weak contact to create interface between them and the problem is solved. |
