Record swirl over time
Old   February 24, 2025, 06:41
Default Record swirl over time
Max
maxaust99 is on a distinguished road
Hi All
I am currently simulating air flow through the lungs and have set-up swirl reports at a number of sections through the airways.
However, as I am using an unsteady simulation, the data resets every timestep. Is there a way of tabulating or plotting this data overtime? I have currently set-up monitor plots which update every timestep but this makes the output window very cluttered as I have 10 swirl reports.
I have heard you can use simulation history but I have found that the simulation can only be set to a specific state (timestep) and so does not tabulate the data.
Any advice would be much appreciated
maxaust99 is offline   Reply With Quote
Old   February 24, 2025, 13:21
Joern Beilke
JBeilke is on a distinguished road
You don't have to plot all 10 monitors in one xy-plot. You can also have 1 xy-plot for each monitor or any other possible combination.
You can also export each monitor into a csv file and do the plotting with another program.
JBeilke is offline   Reply With Quote
Old   February 24, 2025, 15:55
Max
Thanks for your response.
What I mean when the output window is cluttered is that the output which monitors residuals after each iteration is now cluttered with other monitors such as swirl. Just wondered if there was a better way of doing this.
I also have some velocity line probes which record the velocity distribution through the airways. It would be great to see how these change over time but they reset after each timestep.
monitors, solution history, star ccm, swirl, unsteady
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Slow calculation time on CFD server killian153 Hardware 4 July 27, 2021 07:28
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
