Prism Layers on wedge
Old   October 9, 2025, 09:41
Smile Prism Layers on wedge
Francesco Ripandelli
Ripa16 is on a distinguished road
Hello, i'm trying to optimize the mesh for simulating the wedge drop using trimmed cells. As can be seen by the image, in order to avoid high skewness cells and chevron cells on the edge of the surface i used the Convex Angle limit property, however the result isn't that great since i've lost all the layers on the first cells and doesn't have anymore the correct y+ on the edge of the surface.
In the following pictures there are also the prism layer control properties that i have used.
Hope someone could give my some advice, thank you!
Ripa16 is offline   Reply With Quote
boundary layer mesh, edge meshing, prism layer, wedges
[snappyHexMesh] Why does sHM struggle so much with prism layers compared to commercial meshers? CortexShedding OpenFOAM Meshing & Mesh Conversion 0 March 14, 2025 14:34
[ICEM] Prism Layers in 2D AeroFan ANSYS Meshing & Geometry 3 August 11, 2020 03:55
Prism Layers at Slip Wall to Non-Slip Wall Transition InfernoxCJC STAR-CCM+ 4 November 26, 2017 20:06
[ICEM] Prism layers distorted near trailing edge of blade-Unstructured Mesh Rohith Giridhar ANSYS Meshing & Geometry 3 June 29, 2015 18:52
ICEM Prism Layer transition between surface with prism layers and one without TWaung ANSYS Meshing & Geometry 2 October 12, 2009 15:56
