[Sponsors] | |||||
Rep Power: 0 ![]() |
Hello, I just started learning using this cfd, and when I tried to use automated mesh, it uses only one core even though Ive already select parallel on Local host. As for my simulation license, I used the ccm+ power session.
Marc Ricart
Rep Power: 5 ![]() |
Are you sure? keep in mind that:
- Surface Mesh is done in 1 core ALWAYS - Volume Mesh is the one that can be multi-core. to double check, generate the surface mesh ONLY first, and then generate the mesh and compare the CPU usage. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| linear solver crashing during transient run on HPC cluster | Geoff67 | CFX | 3 | August 28, 2020 19:53 |
| Run Mode:Platform MPI Local Parallel core problem | mztcu | CFX | 0 | October 13, 2016 04:14 |
| Pinning the processors in cluster to run a solver | coolcrasher | OpenFOAM Running, Solving & CFD | 0 | November 5, 2015 07:11 |
| Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
| 4 core & 8 core: same 64bit XP, Xeon, x5570, 2.93GHZ | leeruoyun | CFX | 4 | August 19, 2009 01:47 |
