modeling
Old   May 23, 2009, 11:55
Default modeling
filippo
filippo.aero is on a distinguished road
Hello to everyone, I've made some simulation on star-ccm always modeling the fluid region: i. e. a rectangle with a wing-shaped hole for studing flows. Now I make a more complex wing: how can I make the fluid region around it in star-ccm? I hope you understand my problem... thanks in advance
filippo.aero is offline   Reply With Quote
Old   May 25, 2009, 04:34
Maddin is on a distinguished road
When I understand you right you have built a body and around this body the fluid shall flow.
You have to create the "fluid body" - I call it negativ body.
I use Catia for this (bool operator - fast way - maybe somebody knows a faster solution?!).
Maddin is offline   Reply With Quote
Old   May 25, 2009, 05:57
filippo
yes it's right but I'm using proengineer: does it have the same command?
Old   May 25, 2009, 06:01
I don't know. I don't use proE. Maybe your "help" can help you.
I think it should can do the same.
Old   May 26, 2009, 09:45
Thiago Luis Zolet
Zolet is on a distinguished road
1. Import the geommetry
2. Representations -> Import -> Create Surface -> Create Block Surface. In this step you will create the "wind tunnel"
3. Wrapp it!
Zolet is offline   Reply With Quote
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
Solid Modeling Chris Main CFD Forum 10 July 2, 2002 07:12
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 19:08
