November 27, 2020, 10:22 |
#21 | |
Madrigal
Rep Power: 5 |
velocity (but scalar in this case) radius and Vm for the radius and Vm you set your value and for velocity you set what I wrote to you ;-) |
November 27, 2020, 11:53 |
#22 | |
jas
Rep Power: 5 |
Thanks massively for the help. |
November 29, 2020, 04:52 |
#23 | |
Madrigal
Rep Power: 5 |
For Plot: better you do a Scene.. right click on scene... than vector.. star cmm+ take normally velocity from self.. if not.. right click on the blue line and choice velocity... if you want to see the radial velocityprofil so click on the "+" by scene... than click on vector.. after you can see under the properties window "display mode".. there you should to choise "Line Integral"... so you can fast see that your fieldfunction works or not! CFD2DXY Last edited by CFD2DXY; November 29, 2020 at 07:26. |
February 25, 2021, 11:29 |
Cannot evaluate field function Centroid
#24 |
Prit K
Rep Power: 5 |
Hello everyone,
I am trying to create a variable density ( varying with height ) profile in a rectangular domain and the equation I'm using is: 0.2257*(pow($$Centroid[1],3))-0.4868*(pow($$Centroid[1],2))+0.06016*(pow($$Centroid[1],1))+1.301 I'm first generating a report using the expression and when I try to run the report ( after initialization ) I get an error saying: Cannot evaluate field function Centroid. Can someone please help me with this. Thank you in advance. |
Display Modes | |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
