Generate hexahedral mesh
Old   October 10, 2009, 03:23
Default Generate hexahedral mesh
pluto is on a distinguished road
Can somebody please help me with the following. I have an axisymmetric flow that I need to model exiting a nozzle. I have created a 3D mesh. I extruded the nozzle exit boundary downstream to represent the external flow domain. How can I generate a hexahedral mesh from the 3D mesh? Please see attached images.
Thanks
pluto is offline   Reply With Quote
Old   October 13, 2009, 04:23
fnk
fnk382 is on a distinguished road
Hi Pluto,
It seems they do not have standard hexehedral meshing model to tool. They have the trimmer but it produces, for me, a disarrayed set to meshes.
I had to create a nice one in Gambit in order to import it to CCM+. Try that or use Star-CD.
Note that ANSYS, except ICEM hexa (you get this base on license type) does not also come with hexa mesh tools. Once, gambit becomes/is considered obsolete, one will have no choice but stick to the cost effective unstructured grids anyways.
Good meshing Pluto. Oh, and if you figure a way to do this, let me know.
fnk382 is offline   Reply With Quote
Old   October 13, 2009, 16:38
Hi fnk382
thanks for the advice. unfortunately i dont have access to STAR-CD but only to STAR-Design. I have checked on STAR-Design and there is no feature to generate a hexahedral mesh. Its a bit unfortunate that STAR-CCM+ does not have a hexahedral volume meshing tool. for now i will have to continue with the cylindrical extruded mesh. if i figure anything out i'll get back to you
thanks for the help fnk382
Old   October 17, 2009, 15:37
HP Kritzinger
mystic_cfd is on a distinguished road
just a comment to fnk382:
The Ansys meshing platform does have hex meshing capability.
perhaps you should look at the CAE Linux 2009 distro. There are a few freeware meshing tools included which might work for you.
mystic_cfd is offline   Reply With Quote
Old   November 7, 2017, 02:43
Andi
Andi_Didi is on a distinguished road
If you want to have hexahedral mesh in your domain, you can make it manually by direct mesh. Maybe you can learn direct meshing from this tutorial.
I hope it help.
https://drive.google.com/open?id=1ey...NVxwS3pPK6EFcU
Andi_Didi is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 07:08
Use Gambit to generate 3D mesh ! ! ! yuanye FLUENT 0 June 3, 2008 22:03
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
[Other] Problem when trying to generate a new mesh gaottino OpenFOAM Meshing & Mesh Conversion 0 June 30, 2006 07:51
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
