report data at a specific point in 3D domain
Old   August 25, 2009, 11:59
Default report data at a specific point in 3D domain
ahmet
augursal is on a distinguished road
Hi all,
I am new to CCM+ and I am trying to export values (pressure, velocity, etc.) at specific points of my 3D domain. I couldn't figure out which function to use in the reports menu.
Could you help me with this?
Regards
augursal is offline   Reply With Quote
Old   August 26, 2009, 04:15
SKK
SKK is on a distinguished road
If the section you want data from is not one of the boundaries, you can use derived parts to create the required section and then select that in your reports as the part. Then choose your scalar from scalar filed function section of the report properties.
If you want to export data to use in other programs, ie in excel, then use Tools>Tables>xyzInternalTable and similar to reports select the appropriate scalar and parts (ie boundary or derived parts) and then right click on the table name and select extract. Once the data is extracted right click again and select export. The file will be saved in your working directory.
Hope this helps.
SKK is offline   Reply With Quote
reports, star-ccm+
Point cloud data ms Main CFD Forum 1 July 25, 2006 16:54
Overall picture versus specific point Nick Main CFD Forum 0 October 7, 2004 11:25
Data at a specific flow time Arun FLUENT 2 June 1, 2004 21:34
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
Point Data -> Spline -> Iges Tim Franke Main CFD Forum 1 July 6, 2000 12:14
