Freestream Setup in an External Flow Simulation |
October 20, 2009, 18:38 |
I have set up an external flow simulation with supersonic freestream conditions. I have a cylinder around the geometry and I declared the top and bottom of the cylinder as the inlet and outlet respectively, and the sides as the freestream atmosphere. The freestream has zero gauge pressure and a Mach number of 2.0. The problem is that the freestream prevents my simulation from converging...instead it performs a limit cycle behavior (oscillates instead of converges). Any idea what I may be missing?
January 6, 2017, 07:00 |
hirvin chavezu
Rep Power: 9 |
Did you solve your problem?
Simulation Flow Around cylinder 3D | Jwolf | CFX | 19 | November 25, 2009 14:21 |
how to set up high temperature gas turbine flow simulation? | adam2008 | CFX | 1 | July 22, 2009 18:33 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
Simulation of a flow through porous mesh in fluent | G.Vijaya Rama Reddy | FLUENT | 0 | September 14, 2006 00:35 |
Better for Simulation of Dense Solid-Lquid Flow ? | Jeniffer | CFX | 0 | November 22, 2003 19:42 |
