October 12, 2009, 17:37 |
turbulent dissipation rate
Rep Power: 16 |
hi guys,
i am modelling a multiphase flow and when i begin my simulation i am getting a floating point error. the problem appears to be the turbulent dissipation rate (tdr) because as the residuals start the tdr graph continues to increase and does not converge. I've increased the tdr and turbulent kinetic rate (tkr) values and i no longer receive a floating point error. Can somebody please help me in choosing a suitable value for these two rates. the multiphase flow is air and water thanks for the help |
October 15, 2009, 17:19 |
Rep Power: 16 |
Are you working with dof model or steady?
October 16, 2009, 08:56 |
Aroon
Rep Power: 17 |
Do you have the "Cell Quality Remediation" activated in your physics? If you have then you may want to check your initialization.
November 11, 2009, 14:41 |
Rep Power: 16 |
I apologize for the late response. The model is steady. Yes, I have enable cell remediation in the physics model
Thanks for the assistance |
CFX12 rif errors | romance | CFX | 4 | October 26, 2009 13:41 |
Turbulent dissipation rate in UDF | John Deas | FLUENT | 0 | February 20, 2009 12:27 |
Dissipation rate access | K. Kevala | FLUENT | 0 | July 14, 2004 11:11 |
can turbulent dissipation rate be larger than 10e? | Thonstad | FLUENT | 0 | April 29, 2004 03:54 |
calculation of (turbulent) dissipation energy ? | max | Main CFD Forum | 3 | August 18, 1999 09:42 |
