Largest Internal Volume does not exist. Try reducing the smallest relevant volume
Old   December 14, 2009, 11:43
Default Largest Internal Volume does not exist. Try reducing the smallest relevant volume
robinfisichella is on a distinguished road
I was doing the basic manifold meshing tutorial supplied with CCM+ ver 4.04.011 and got the following when trying to wrap the surface:
Wrapper::generateOctreeMesh: Largest Internal Volume does not exist. Try reducing the smallest relevant volume or reducing refinement sizes.
Can anyone help me out here, is this a user induced error or a problem with the program.
robinfisichella is offline   Reply With Quote
Old   December 14, 2009, 12:02
I reduced the gap closure size to 50% of base size and now it completes the wrapping, is this because i had holes in my surfaces then?
I noticed a couple of small holes afterwards but i didnt think this would produce a server error?????
Old   December 14, 2009, 13:13
Arconis is on a distinguished road
I think that you didn't close the manifold inlet pipe part well. It's not easy to click where you want all the points so rotate the geometry to see if it's really closed
Arconis is offline   Reply With Quote
Old   December 14, 2009, 13:40
ok thanks ill give it a try!
Old   March 16, 2019, 16:35
Enric
EGK87 is on a distinguished road
I agree with robinfisichella, what you have to do is to reduce the mesh dimensions of the Surface Wrapper. i.e. changing base size, or reduce directly the gap closure size.
Thanks robinfisichella!
EGK87 is offline   Reply With Quote
Old   August 16, 2021, 07:48
SHM
SHM is on a distinguished road
Hey
I have the same problem, getting the same error when I want to execute mesh, I changed the Gap closure size but did not work, do you have any other recommendation ?
many thanks
SHM is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
