Error while importing xy plot from Fluent to StarCCM+ |
April 3, 2010, 13:41 |
Benoit
I have a problem using StarCCM+. I would like to use some results from Fluent analysis (XY Plot, .xy format) but when I try to import data (using Tools->Tables) I get an error message. I used to work with Fluent and it's important to me to be able to import all plots from Fluent to use them in StarCCM+. In StarCCM+ help, it is specified that the software can use .xy files but apparently there is something in the syntax of Fluent files that is not supported with StarCCM+. Is there someone who had ever had this problem? Thank you in advance for your response. |
April 3, 2010, 17:16 |
Rep Power: 17 |
You can import a mesh from Fluent into STAR-CCM+, but not plots. You need to explain what you intend to do with the data in order to figure out the best way to import it.
April 3, 2010, 19:21 |
Benoit
Thank you for your answer.
What I am trying to do is displaying on the same plot data calculated with StarCCM+ and data extracted from a .xy file (created with Fluent). I know I can use .xy files to create a Table and then use it to plot the data but the syntax used in the Fluent file generate an error in Star CCM+. Is there any way to fix this (except by modifying the original .xy file with a text editor, which is quite complicated when you have several different files). |
Importing Gridgen into Fluent | travis.moulding | ANSYS | 4 | April 5, 2010 09:38 |
Importing TrueGrid mesh in Fluent | dipankar | FLUENT | 0 | October 16, 2009 18:22 |
plot x,y on fluent | Ricky | FLUENT | 1 | May 27, 2009 06:18 |
THE airfoil CP PLOT IN FLUENT IS JUST NOT POSSIBLE | Rif | Main CFD Forum | 3 | February 6, 2008 11:13 |
Importing a structured mesh into Fluent | Flav | FLUENT | 0 | November 30, 1999 10:57 |
