December 28, 2009, 12:31 |
Massflow report/monitor in CCM+
Erez Raviv
Rep Power: 17 |
I'm simulating a radial impeller. I've modeled a single channel with periodic BC's and so far I'm getting very good results. The simulation converges quickly, the velocities and pressures are right but the massflow is about 1/100 if the expected values. Even when I use a massflow inlet and specify the correct flow the report shows low values. I'm pretty sure that the results are physical but I'm doing something wrong while creating the report/monitor. Any ideas? |
December 29, 2009, 02:36 |
Joern Beilke
Rep Power: 20 |
Check the size of your domain. Maybe there is something wrong with meters and feet.
December 30, 2009, 09:34 |
Erez Raviv
Rep Power: 17 |
Hi beilke,
I've checked and the domain is fine. The speeds and pressures are also fine. Is the massflow averaged over the entire patch or is it indicative of only one cell? |
December 31, 2009, 02:30 |
Erez Raviv
Rep Power: 17 |
Solved it!
I was using area averaged and not massflow report. |
impeller, periodic, radial |
calculate MASSFLOW for a component | MAldaz | CFX | 1 | November 7, 2007 11:41 |
error in star ccm | maurizio | Siemens | 3 | October 16, 2007 05:17 |
massflow outlet in flunet. | shrinath | FLUENT | 0 | September 3, 2007 09:40 |
re: Massflow reset in CFX 10 | Wooster | CFX | 5 | March 16, 2007 20:08 |
about the massflow rate boundary condition | whitemelon | FLUENT | 0 | June 3, 2006 05:44 |
