February 13, 2010, 05:55 |
visualising y+ and forces
Hello I'm new to CFD and am struggling to visualise the results, if the data is already then it maybe just a case of not clicking the right visualisation button.
I'm using realizable k-epsilon in simulating a stationary object in a tunnel and wondering how, if possible, to view y+ and viscous forces. Hope someone can help, thanks. |
February 15, 2010, 07:13 |
Rep Power: 18 |
Y+ you only can see on the walls - you must include the wall boundary to you scalar parts.
February 15, 2010, 08:26 |
Thanks for your reply, that would explain why it looks blank. So far without success obviously I had tried adding a report and making a monitor from it, which was guess work, is there a proceedure for simply adding it to the existing system or does it require more complication to the model? Thanks
Forces in V1.6 | terrybarnaby | OpenFOAM Post-Processing | 72 | September 2, 2015 16:49 |
Forces calulated through pressure | LVDH | OpenFOAM Post-Processing | 2 | February 26, 2010 03:15 |
Calculate forces without hydrostatic pressure | geir_oye | FLUENT | 4 | November 12, 2009 09:12 |
changes to forces in 1.6 | linnemann | OpenFOAM Running, Solving & CFD | 0 | July 30, 2009 08:49 |
Valve Forces in CFdesign | Mike Clapp | Main CFD Forum | 3 | March 8, 2001 14:09 |
