Total Pressure only increases
Old   February 10, 2010, 12:10
Default Total Pressure only increases
Maddin is on a distinguished road
I made a simple intercooler simulation.
The total pressure of inlet and outlet of the core (actually without porous medium) only increases and didn't get constant. But pressure drop is nearly constant.
K-Omega, steady - good poly mesh.
Temperatures etc. are constant, only pressure fools me.
The core is connected via 2 interfaces, total pressure report runs on the interfaces.
Somebody an idea? unsteady effects? faults in the report because of the interface?
Maddin is offline   Reply With Quote
Old   February 10, 2010, 12:28
Argh.. I think I found the error. The "old" ccm bug with interfaces.
I tried the other side of the interface and there the pressure seems to be constant - but I will test it.
Old   February 11, 2010, 04:12
No that wasn't the solution, same "trend"...
Old   February 15, 2010, 07:14
Problem solved, used coupled flow... don't know why I used the coupled but with segregated all is fine.
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Static Pressure, Total Pressure ufechner FloEFD, FloWorks & FloTHERM 5 March 2, 2015 07:56
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Total pressure exceeds inlet value Tom CFX 1 September 9, 2008 22:02
Total pressure to static pressure ratio roadracer Siemens 1 April 17, 2003 05:31
