August 26, 2010, 11:01 |
mesh generation help
Rep Power: 15 |
I am a new STAR-CCM+ user. I have a large model that I'm am trying to get a surface and volume mesh on, but the surface mesh generator keeps cutting off one end of the model and adding holes, kind of like someone had a field day with a chainsaw. I think it's doing this because that section is where two components gradually come together, so the cross section of the space between the parts would look like a long skinny triangle. That geometry continues around the entire top of the model. I've tried tweaking the mesh settings, but have not found a way to mesh up into the small corner. That's really the only trouble spot, everything else seems to mesh fine. Any suggestions would be appreciated. Thanks
August 27, 2010, 02:10 |
feature curves missing?
Christian Jungreuthmayer
Rep Power: 17 |
Did you create "Feature Curves" for your regions?
Christian |
August 27, 2010, 04:01 |
reduce mesh size or create feature curve
u can eliminate this problem by reducing mesh size(if it possible) or create feature curve
August 27, 2010, 14:38 |
Rep Power: 15 |
Thanks for the suggestions.
Tron: The regions do have feature curves defining the boundaries but it will not mesh up to the feature curves. karthickeyan: I have tried finer meshs, some extend further up into the region and some don't for some reason. This is a large model, so I don't want too fine of a mesh beceuase that will increase the computation time. I think we once tried to do a fine mesh on just the region we are trying to fix, but it had issues connecting that to the rest of the model which had a bit courser mesh. |
August 27, 2010, 16:10 |
Vinicius Girardi
Rep Power: 17 |
Split the faces that are in touch in 2 boundaries and customize the mesh values for both. Use the min and target with the same value (for example 50% for both). Also, if it doesn´t help, disable the automatic surface repair and see what happens.
Are you using surface wrapper? |
August 30, 2010, 01:19 |
try this
for each boundary u can customize the mesh size so upload snap shot of ur problem
September 11, 2010, 17:20 |
Rep Power: 15 |
So far I have tried all the suggestions and still can't get a good mesh up into the corner. I got a new higher fidelity model to play with, in an STL format, and I can't even get that to remesh or surface wrap or anything. Sorry, I can not upload any pictures or my model, I can only describe the geometry generically.
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
ICEM - incomplete mesh generation | ralph | CFX | 0 | June 23, 2008 23:35 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 13:47 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
