Finite Wing Simulation
Old   February 4, 2011, 10:36
Arrow Finite Wing Simulation
Altocirrus is on a distinguished road
I’m trying to simulate a glider wing (15m span, 0.7m chord, Eppler 603 airfoil) flying at 25 m/s (Reynolds number = 1200000). I'm teaching myself Star-CCM+ for this purpose, but with very little information to go on and no support I'm having a hard time getting accurate results. I’m validating against XFLR5, as well as performance values for a glider using this wing. Induced drag is the primary interest of the project, so the bounding box extends beyond the wingtip to simulate tip effects. I’d really appreciate your thoughts on the following:
  • The size of the bounding box: The Star-CCM+ documentation suggests that a chord length away from the wing surface is sufficient, but this seems close to me. My boundaries are currently 3x the chord length away from the wing.
  • Mesh density/ cell size: I don’t think this is the main issue, but I was wondering whether there is a ‘rule of thumb’ for setting these values.
  • Mesh type: I’ve tried polyhedral and trimmer meshes, and polyhedral has so far seemed to give more accurate results (my trimmer meshes seem of low quality for some reason). However they use much more memory and simulations take far longer, so there is more scope for increasing the trimmer mesh density.
  • Prism layer mesh: I’m unsure on the number/ thickness I should use.
  • Turbulence modelling: As a glider wing, I imagine the flow over the wing’s surface will be predominantly laminar, so do you believe the laminar flow model would be sufficient? If not I’ll use the Spalart-Allmaras model combined with turbulence suppression. Any tips or suggestions for values I should for these models?
  • Any other things I should bear in mind for finite wing simulation?
Sorry for asking so much, but I’d be extremely grateful for any advice! Better yet, if anyone knows of any relevant tutorials or (better still) example .sim files to have a look it would be a huge help. I've spent weeks on end trying to improve accuracy, and it seems mad to start from scratch when this is a fairly standard aerospace problem that has probably been done throusands of times before.
Thanks
Altocirrus is offline   Reply With Quote
Old   February 7, 2011, 12:41
Default Cd-adapco Staff
Anonymous
Ash_D is on a distinguished road
If you can send me your email address I can get one of our technical team members to send you some suggestions for your modelling requirements.
Best Regards
Ash
ashkan.davoodi@uk.cd-adapco.com
Ash_D is offline   Reply With Quote
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 13:46
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 11:31
Overflow problem in steady simulation ReeKo CFX 11 October 8, 2008 17:57
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
Postprocessing Pressure data spanwise over a wing Rick FLUENT 1 February 3, 2006 09:28
