March 6, 2011, 16:33 |
Multi-element airfoil
Aaron Long
I'm new to CFD and I'm running a 2D multi-element wing in STAR-CCM at various angles to measure the lift and drag coefficients. I have tried using different meshes and I have been unable to get the results and stall point to match with previous results. I am using a k-epsilon turbulent, consent density model. What can i change to give me accurate results? |
March 6, 2011, 16:42 |
Aaron Long
I forgot to mention that the wing is in air at 30 m/s
March 15, 2011, 19:36 |
John
Rep Power: 16 |
From my experience with multi-element airfoils, kepsilon gives a more accurate Clmax, but doesn't indicate stall angle correctly, whereas the transition model seems to predict stall angle correctly but underestimates the Clmax.
I don't think there is anything out there available commercially that does a good job of predicting stall, but I could be wrong. |
April 1, 2011, 07:47 |
Rep Power: 15 |
also, stall means flow separation which I gathered from these forums makes the problem unsuitable for 2D, you should work in 3D instead.. but my experience in CFD is very low I stand corrected..
Display Modes | |
Problem running simpleFoam on a multi element airfoil | vinz | OpenFOAM Running, Solving & CFD | 18 | April 11, 2013 11:26 |
Question about reference values --> Area (multi element wing) | Zweeper | FLUENT | 7 | March 28, 2010 11:29 |
Modelin Multi Element Airfoils | Yashwant Ganti | FLUENT | 0 | June 5, 2007 03:50 |
multi element airfoil data | shadi memarpour | Main CFD Forum | 0 | June 20, 2004 04:33 |
Multi Element Airfoil | J.Dumas | Main CFD Forum | 2 | May 13, 2000 07:24 |
