parallel session mpi problem
Old   April 4, 2011, 16:01
Default parallel session mpi problem
ecto is on a distinguished road
I'm running STAR CCM+ 4.04 on a win64 machine.
When I select a new parallel simulation the program says "Warning: no MPI distribution found."
I installed MPICH version which came with the software, it's mpich.nt.1.2.5.exe and registered it with my account.
The system has only one account, without password to enter.
Can someone please help me?
Thanks a lot
ecto is offline   Reply With Quote
Old   April 4, 2011, 18:58
Nobody?
I think this is a common issue in win64
Old   April 5, 2011, 04:48
Maddin is on a distinguished road
I have no account created and it works. Try without account.
Did you started the server? Firewall allows the access?
Maddin is offline   Reply With Quote
Old   April 5, 2011, 05:48
I have windows 7, and I have one account as administrator. I tried with and without password. Are you talking about the license server? If yes, this it's ok. I also tried with the windows firewall off , no changes. How can I understand if MPICH works correctly?
Now I installed the newer version of MPICH2 for windows 7 64bit, but no changes: "Warning: no MPI distribution found."
What do you think?
Thanks for the help
What do you think?
Thanks for the help
Old   April 5, 2011, 05:59
mmaukii is on a distinguished road
Had also mpi problems on different systems! What acutally worked on all of them as solution was to reinstall STAR-CCM!
mmaukii is offline   Reply With Quote
Old   April 5, 2011, 06:06
I see... And I should install mpich before or after ccm? Have you got experience on windows 7 64bit?
Old   April 5, 2011, 07:28
if you install starccm with normal options it normaly installs mpich2 automatically (at least newer versions). For me i had exactly that problem on a win7 64 bit. Tried to install hpdmi and mpich by myself, nothing worked. But the good old reinstallation solved every thing.
Old   April 5, 2011, 07:51
I understood you wrong - you also can work with accounts in MPI.
There I had problems with using an account.
When you have the config of the MPI open you can check that the server is running.
Old   April 6, 2011, 04:57
I incredibly managed to make it work!
That's what I did:
download the latest mpich2 installer 64bit on desktop (it's "something .msi")
open the dos prompt with administrator priviliges and go onto the desktop, here use "msiexec /i something.msi" to launch installation of mpich2
install for "everybody"
it works!
Old   April 6, 2011, 04:58
And I didn't reinstall ccm+
Old   April 6, 2011, 05:28
nice. So i know also for the next time an easier way!
problem in the CFX12.1 parallel computation BalanceChen ANSYS 2 July 7, 2011 10:26
Parallel UDF problem, hello world version pilou FLUENT 0 March 10, 2011 08:20
A Strange Problem in making Parallel (Ansys/CFX 12) a.sarami CFX 13 October 7, 2010 01:33
problem using property udfs in parallel mode EllenW FLUENT 0 June 23, 2009 17:18
MPI and parallel computation Wang Main CFD Forum 7 April 15, 2004 11:25
