April 20, 2011, 05:59 |
new in star CCM+
nitin
hi,
I am just stared using starCCM, I have 3 D proE model of a turbomachine. But now i am unable to define parts and meshing and simulations. Please if anybody has good example of best tutorials or any document please guide, Thanks |
April 20, 2011, 06:44 |
Chk out control valve meshing tutorial
April 20, 2011, 06:47 |
hi
nitin
Thanks,
Just now., i am practising the same tutorial other than this if you have any excellent tutorial or document please share thanks |
April 20, 2011, 23:39 |
hi
nitin
hi
just now, i am following that tutorial to my problem (turbomachinery) i know very well icem and CFX compare to that i want to make parts and 3 domain body. how to make it in starccm i am unable to do. please guide |
April 21, 2011, 00:13 |
Please refer the solidification tutorial (ice forming) it explain how to create multiple domains, also for region creation in an imported geometry again refer control valve tutorial. If you are familiar with ICEM and still have access to it I would suggest you use it for meshing after creating proper blocking, if you want structured meshing, because as such I was not very impressed with auto hexa mesh generator which creates something similar though not of that quality. |
April 21, 2011, 02:51 |
hi
nitin
thanks
I learnt alot from that tutorial like how to prepare parts as we do in ICEM but still i am unable to make proper region. Actually i am simulating a centrifugal pump, contain a stationary domain called casing and a rotating domain called impeller when i am importing iges, it is always coming three region trmsrf 1,2 and 3 1 contain all domain stationary as well as rotating and trmsrf 2 and 3 are interface surfaces. so how shoud i go ahead, i am unable to decide. Please guide me. thanks |
April 21, 2011, 05:42 |
hi
nitin
in continuousnation with above problem
i am doing meshing of a 3D ractangular block, i started with parts, now i did generate volume mesh but it is not visible, how to see the volume mesh? |
April 21, 2011, 05:49 |
Right click in the display area
Apply representation and click on volume mesh |
April 22, 2011, 02:37 |
hi
nitin
hello
please back to the pump problem , i am now imported pump iges file from surface mesh. and selected region part. I am here attached a photograph of the situation, please lok to the output window. I did surface topology, it is showing "Region TRM_SRF contained only one topological region and was not split." like this i m getting the msg. Actually you can see from the figure that i have to have three regions, why , because i made 2 interfaces, it is like water is entering from inlet, i.e. inlet extention and then 1 interface. now water moves towards impeller and this is 2nd domain, inbetween impeller and casing their is one interface, we define as frozen rotor in CFX. how to split region, i am unable to solve it. please guide and also i want to know why trmsrf 1 and 2 is for. actually that trmsrf is nothing but two interfaces. thanks |
April 23, 2011, 07:58 |
hi
nitin
i learnt something from the tutorial
still i am unable to split the region. but fortunately, i found that if i make domain separately in the 3D model in proe and import to surface mesh in starccm. i am able to solve my requirement. is it the best way? or something else that i can do? |
April 26, 2011, 06:34 |
hi
#11 |
nitin
hi
i have now done with meshing now as we do frozen rotor for rotating and stationary domains, interfaces likewise, i want to do in starccm+, how to do it? i have prepared the interfacecs (inplace) i am following that rotating frame tutorial. also plz tell me, how to define rotation of the impeller? which is the best BC for pumps i am using mass flow inlet and pressure outlet. please guide thanks |
July 6, 2011, 18:10 |
#12 | |
I wonder how to create another region from a imported geometry because I want to create a porous media region which should be part of the imported geometry. However, it's continuous when I made this geometry using solidworks. Thanks, |
star ccm+ |
Fluent Vs Star CCM | firda | Main CFD Forum | 3 | February 26, 2011 02:51 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
A genearl question on STAR CCM | nstar | STAR-CCM+ | 5 | June 24, 2009 09:39 |
error in star ccm | maurizio | Siemens | 3 | October 16, 2007 05:17 |
