enass massoud |
May 13, 2016 08:09 |
Originally Posted by niriosrat
(Post 365026)
Thank you for the help with the velocity, I have also another question. I need to monitor: 1) the length of the slug bubbles and 2) the liquid film thinness (between the bottom of the tube and the bubble inter-phase).
For 1) I think I will define just a monitor of phase located in the top to know if is gas or liquid and determine after the distance based on the time step. For 2) I though to define a line on the radial direction as after extract the volume fraction vs height. I wonder if can be a more "automatic" option to determine the height of the liquid thickness?. Or which other options do you recommend. I hope I made myself clear.
Did you mnage to solve this problem???
