June 8, 2011, 15:52 |
mesh within certain angles
Rep Power: 15 |
Hey guys,
How to deal with mesh in the sharp angle area as marked in the attached picture? The problem is that the room becomes narrower when it approaches the thinner corner. The skewness angle there is very large. Is there any tool in the starccm I can use to solve this problem? Thanks for any help! |
June 10, 2011, 13:51 |
Dave
Rep Power: 15 |
If your issue is specifically with a prism layer in that area, you can try changing the layer reduction percentage and minimum thickness percentage under the prism layer mesher options.
June 10, 2011, 15:21 |
Rep Power: 15 |
Thanks but what I'm concerning now is not the prism layer but the mesh in that area. Do you have any idea of how to deal with the sharp angles?
June 11, 2011, 07:03 |
Dave
Rep Power: 15 |
Perhaps try refining either the surface or the volume cells using a volume control? You could also refine it and modify your geometry to eliminate the corner's point such that the if the modification is very minor it will have minimal impact on the resulting flow. I am not sure how important capturing the flow in the smaller end of the corner is to capturing your flow without knowing the details of what you are trying to capture.
June 11, 2011, 10:27 |
#5 | |
Ryne Whitehill
Rep Power: 18 |
June 15, 2011, 15:29 |
Rep Power: 15 |
Thanks. I'm interested in the feature curve way. Could you please explain more in detail about how to use it to control the surface mesh in that area? Thanks.
June 15, 2011, 15:31 |
#7 | |
Rep Power: 15 |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 04:27 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
Mesh Refinement | JY | Siemens | 7 | September 19, 2002 13:37 |
