How can i animate an unsteady simulation in Star ccm |
July 7, 2011, 07:28 |
Elena Cortin
Rep Power: 17 |
I run a simulation of 1000 iterations and i would like to see all the timesteps from the first to the end as an animation
So how can i do that? i can not find any tutorial Also how can i delete the last 100 iteration and start from the 900 ?? |
July 7, 2011, 08:30 |
You can export the scene at a set timestep interval, and then compile in movie maker or a similar program. To do this go to
scene > attributes > update then click on the save to file button and specify the directory. If you click on the update frequency tab can set how often the file will export. As for the second question, I would probably set to autosave every 100 timesteps in 2 files (so one file saves the 100, 300, 500 etc up to 900th timestep) and then restart from that point. Hope that helped Ste |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
simulation created in star CCM 5.06 | yin | STAR-CCM+ | 1 | May 4, 2011 02:29 |
Fluent Vs Star CCM | firda | Main CFD Forum | 3 | February 26, 2011 02:51 |
CFD-analysis of hydroplane: STAR CCM or Flow Simulation? | peterg07 | Main CFD Forum | 0 | February 7, 2010 14:32 |
Procedure to run unsteady simulation? | STN | Main CFD Forum | 2 | February 16, 2002 04:37 |
