collapseEdge:2582: edge not replaced!
Old   August 12, 2011, 03:39
Default collapseEdge:2582: edge not replaced!
emir aydar
eaydar is on a distinguished road
when i try to mesh a model for two continuum (solid-fluid conjugate heat transfer problem), begining of the mesh, starccm+ try to merge same boundaries for each region and then one boundary can not be merged and, there is a message as shown in below.
Merging boundaries for interface In-place 3:
calling face imprinter with tolerance=0.00542246
EdgeMerger:MKMesherCommon::EdgeMerger::InternalDat a::collapseEdge:2582: edge not replaced!
Error during surface remeshing, deleting resulting mesh
EdgeMerger:MKMesherCommon::EdgeMerger::InternalDat a::collapseEdge:2582: edge not replaced!:
Command: GenerateSurfaceMesh
CompletedCommand: GenerateSurfaceMesh
In: [Machine::main]
Recoverability: Non-recoverable
error: Server Error
What does it mean? How can i resolve the problem?
Urgently help me!!!
eaydar is offline   Reply With Quote
Old   August 16, 2011, 04:01
Matthias Fitl
MFitl is on a distinguished road
In: [Machine::main]
error: Server Error
Probably the boundaries defining the the interface between solid and fluid do not fit together well.
Solution:
  • Within the solid surfaces take those surfaces defining the interface to the fluid.
  • Click with right mouse botton "Create Interface" --> new boundary with the solid region is defined (copy of first)
  • Make new region from boundary (right mouse botton). This will be the region of the fluid.
  • Close the fluid region as needed.
As the new boundary surface/region is a 1:1 copy of the solid surface you will get a working interface.
best regards,
Matthias
MFitl is offline   Reply With Quote
Fortran to Fluent sixfor FLUENT 2 January 8, 2011 15:06
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 01:07
