November 24, 2011, 03:54 |
Problem with free surface ship hull
i have the following problem (picture) when i run a resistance calculation. Normaly i have a finer mesh (0.1m for the hull and stretching to 1m - free surface), but the result is the same. I get this behaviour only when i work with prismatic layers. When i change the under - relaxation factor from k-e turbulent viscosity from 1.0 to 0.3 or 0.1 i get a normal behaviour. With hex i must also change the under relaxtion factor from k-e turbulence and segregated vof to 0.4 or 0.3. Is there any way to avoid the change from this factors? With polymesh i only must change the under relaxation factor from k-e turbulent viscosity. With hex itīs conspicuous that the water takes al long time to flow over the bow. With the default values the water has a behaviour like honey. Without prismatic layers my results are very good (for pressure 141KN share force 290KN NET 431KN). With prismatic layer the pressure is to high, shear to low and net ok. Mesh: fine-15.000.000 cells coarse-5.000.000 cells Top,bottom, left, front = inlet (velocity) back = outlet (hydrostatic pressure of wave) ship = wall symmetrie VOF 6 DOF multiphase primsatic layer thickness 0.03m layer 10 stretching 1.2 ship lenth 141m velocity 9.2m/s (for air and water) Re=1.1e9 farfield (top 26m bottom 65m left 90m length 650m) timestep 0.1 - 0.3s iteration 5 Y+ 30-300 Turbulent viscosity ratio 10 (default) - 1000 (depends on mesh) Thank you very much alfaben Last edited by alfaben; November 25, 2011 at 13:22. |
free surface around a ship hull | Stephy | OpenFOAM Running, Solving & CFD | 12 | April 24, 2012 01:12 |
Rising/falling free surface problem | rjmcsherry | CFX | 4 | September 2, 2011 04:46 |
Free Surface Simple problem | Luk | CFX | 0 | July 25, 2006 07:19 |
free surface problem PLEASE HELP ME | varshavian | FLUENT | 1 | February 17, 2003 06:07 |
CFX 4.4 New free surface option | Viatcheslav Anissimov | CFX | 0 | April 3, 2002 06:27 |
