non-manifold error
Old   December 13, 2011, 10:06
Unhappy non-manifold error
vincent
vinvalt is on a distinguished road
I want to obtain my fluid domain by either extracting the internal volume or using the boolean operation substract or intercepts on my geometry which I imported under; import CAD Model. However all my attempts resulted in error stating on one hand,
"feature execution failed, non manifold body extracted"
and on the other hand,
"feature execution failed, substractbodies: substract will produce non manifold body"
can you help me with a step by step method of dealing with these two scenarios so as to obtain the fluid domain.
Also what are the steps for dealing with free edges and non-manifold edges and vertices
vinvalt is offline   Reply With Quote
Old   January 2, 2012, 18:54
abdul099 is on a distinguished road
I can't provide a step-by-step method since I don't know anything about your geometry. All I can try is giving some hints. When your imported part has some free edges or some other errors, try to get rid of them before importing the geometry (when possible). Otherwise import your geometry on the part level (not CAD modeller) and repair all errors by hand before performing boolean operations.
Again I can't give you any step-by-step methods how to get rid of free edges, non-manifold edges or non-manifold vertices since it depends on your geometry. Sometimes you can fill free edges, you might zip some, you might make an intersect and delete some faces etc... Try to understand what a free edge, a non-manifold edge etc. means and you will see what to do.
abdul099 is offline   Reply With Quote
boolean, extract, free edges, internal volume, non-manifold
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
