Feedback - Evaluate Residuals
Like Tree1Likes
  • 1 Post By abdul099
Old   February 14, 2012, 02:46
Default Feedback - Evaluate Residuals
eRzBeNgEl is on a distinguished road
Hey guys,
I need your help to evaluate the attached Residuals. My set-up is described in the following:
-Computational Domain: Centrifugal fan with volute
-1500 million cells - polyeder unstructured
- k-e Modell : implicit transient - sliding mesh
- Time Step: 2,35e-05 (1 degree rotation each timestep
- 2nd order High Resolution
- Segregated Flow
- 7000 U/min
Following questions do I have:
- Where do the peaks in the residuals come from?
- Why are they in average on a very high level? The mesh, geometrie and set-up is OK.
-Next step I am trying coupled solver improving the residuals
- Between which Re number can I switch from segregated to coupled?
- General ideas and suggestions from your side
Thanks for help
eRzBeNgEl is offline   Reply With Quote
Old   March 1, 2012, 08:21
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
From the figure, it seems that the solution did not converge. So, check it to improve the mesh quality.
The peaks could point to the start of new time step, I do not know how many iteration you had for every time step.
Good luck
siara817 is offline   Reply With Quote
Old   March 4, 2012, 15:44
abdul099 is on a distinguished road
First of all, the residuals in Star-ccm+ are normalized. Don't bother about the level of the residuals.
Second, I don't know where the peaks are coming from. But like siara817 said, check the mesh quality. Also the time step etc. Maybe you need more inner iterations (don't know if you changed that). Set the trigger type for residual monitors to iteration, you should be able to see what happens within a time step.
Using the coupled solver will not help very much since something else seems to be wrong. That's like trying a different saddle on a dead horse.
By the way, are you sure, your mesh contains 1500 MILLION cells?!?
siara817 likes this.
abdul099 is offline   Reply With Quote
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
what to monitor besides residuals? franzdrs FLUENT 5 March 21, 2013 03:59
Mesh size and solver residuals... Scott CFX 5 December 15, 2008 17:10
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
residuals Karl CFX 2 June 24, 2003 23:13
