Source Term
Old   March 12, 2012, 09:22
Default Source Term
itsme_kit is on a distinguished road
Once I got the graph where flow rate against pressure
How can I get this result as a source term in to Star-ccm?
Thanks
itsme_kit is offline   Reply With Quote
Old   March 12, 2012, 09:23
The resullt is taken from modelling a diaphragm pump
Old   March 14, 2012, 08:46
Ryan Coe
ryancoe is on a distinguished road
There's a fan model you can be use with a momentum source region that I think should do the trick.
Ryan
ryancoe is offline   Reply With Quote
Old   March 14, 2012, 16:34
Actually it is a diaphgram pump
Old   March 15, 2012, 08:08
Ryan Coe
Unless you want to model the temporal phenomena of the pump (in which case you'll need to know more than flow rate vs. pressure), you can still input your curve into the fan model, right?
Ryan
momentum source term zwdi FLUENT 14 June 27, 2017 15:40
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
