Problem in running STAR-CD Case in multiple processors |
May 6, 2014, 09:53 |
Vignesh
I am running a case in STAR-CD. The case runs fine in 1 processor. However, when i execute it in 2 or more processors, i am getting the error: Error encountered, number: 76 *** Error 076: Negative densities found at more than 100 cells. RUN STOPPED !!! PNP: Shutdown [2014-05-06-15:46:48] Execution terminated after 82 seconds (OVERALL ELAPSED TIME). [s126787@node021 Case_750K_15O2_Inj_Pr_6MPa_sr200_parallel]$ Then i checked the .info file. I found the following warning: *** Warning 056: In domain 1 one of the following values for initialisation is too small: k or epsilon for KEPS option or turbulent intensity or mixing length for MIXL option. Initialisation method is now MIXL with turbulent intensity 2.582E-02 and mixing length 1.000E-01. Any suggestions to solve this problem? |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 04:03 |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
problem in running parallel: ./Allrun: 62: shift: can't shift that many | adambarfi | OpenFOAM Running, Solving & CFD | 10 | May 11, 2015 09:31 |
pro-gl.exe problem in star cd | alqadri88 | Main CFD Forum | 0 | November 10, 2010 04:38 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
