Home > Forums > Software User Forums > Siemens > STAR-CD
phi-T plot
Old   October 29, 2013, 15:14
Default phi-T plot
Jason
lunar1984 is on a distinguished road
Hi All,
I am currently conducting diesel cycle simulation with STAR-CD 4.16. I am wondering if it is possible to get phi-T plot which can explain the soot and NOx formation. The example of phi-T plot is attached.
Thank you in advance.
lunar1984 is offline   Reply With Quote
Old   November 7, 2013, 09:37
Jason
Does anyone have an idea about it? Still waiting for the solution.
Thanks.
Old   May 6, 2014, 09:59
Vignesh
pmrvignesh is on a distinguished road
Hi Jason,
In order to plot phi-T, you need to calculate phi. phi= equivalence ratio= Mass.fraction of fuel/Mass.fraction of air(oxidizer).
Your CFD calculations would have yielded the mass fraction of fuel and oxidizer, in all the cells. You can then use those values to calculate phi, and then plot against temperature values.
pmrvignesh is offline   Reply With Quote
Old   May 19, 2014, 06:25
ok_computer is on a distinguished road
one thing is also how you calculate Lambda or Phi. This should be calculated so that it is based on the mixture fraction e.g. from
Lambda = (m_fu_st(1-f))/f(m_o2_st+m_n2_st)
where f is mixture fraction and m_fu_st is the stoichiometric fuel mass.
ok_computer is offline   Reply With Quote
[OpenFOAM.org] OpenFOAM build on Intel Xeon Phi asaijo OpenFOAM Installation 31 July 26, 2017 10:35
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
Summing phi over all faces in patch NewtoFOAM OpenFOAM Programming & Development 2 May 8, 2013 05:37
Turbulence Model phi vs phi_ doug OpenFOAM Running, Solving & CFD 4 November 10, 2009 04:33
graph plot anindya Main CFD Forum 2 September 17, 2003 12:00
