September 22, 2014, 05:37 |
Trimming error
Ived
Rep Power: 12 |
Hi all,
I am working on a geometry that is already trimmed but with the old piston. So now I have deleted the old piston and added new piston geometry, selected cylinder and piston to training panel and have cut the 3D template without modifying the 2D template. After creating the 3D template I am unable to cut. When I try to trim it is giving me error as ‘spline was not used to define edges because it has knot (1) that is not on a vertex of a cell in the cset’. Failed to cut the template. Am I doing any mistake here? Pl advise. Thanks in advance. Regards, |
October 14, 2014, 05:01 |
AB
Rep Power: 15 |
You probably still have splines that were defined by the old piston geometry.
Go to geometry and do sset recall 3 then delete all the splines that were on the old piston, and define your new splines on the new piston. |
November 17, 2014, 01:47 |
Krishna
Rep Power: 14 |
can you please let me know, where u r trying to combine new piston and old port geom.
you should not do in es-ice. First, you have do all in star ccm and check the connectivity and load to es-ice. it will work. update me |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
